Still a mechanical joint though , whats this section in the 17th that Ian is on about , how does it affect jointing a cable ? A joint is either mechanical or sweated . I wonder what he calls not accessible , under floorboards or what ?
hammer and bolster gains access to most places,Still a mechanical joint though , whats this section in the 17th that Ian is on about , how does it affect jointing a cable ? A joint is either mechanical or sweated . I wonder what he calls not accessible , under floorboards or what ?
Clause 526.3 - have u got a copy of the 17th ??Still a mechanical joint though , whats this section in the 17th that Ian is on about , how does it affect jointing a cable ? A joint is either mechanical or sweated . I wonder what he calls not accessible , under floorboards or what ?
Clause 526.3 - have u got a copy of the 17th ??Not accessible - joint is in a grd flr ceiling void that
Nice bit of plagiarism steps with a twist of artistic licences Applaud SmileyApplaud Smiley - I like the uncle Albert bit, trotters indepent traders stike again :^O :^OSorry for the rant its nothing personal toward steptoe just been one of them days putting right the F-ups of the home owners distant uncle Albert who worked as a spark for a bit or so they say NOT!!! its clearly horse poo
just mind your chandeliers, or was that grandad. ?:|Nice bit of plagiarism steps with a twist of artistic licences Applaud SmileyApplaud Smiley - I like the uncle Albert bit, trotters indepent traders stike again :^O :^O
It was grandad - hooray for ukgold and the daily fix of proper comediesjust mind your chandeliers, or was that grandad. ?:| just trying to point out ian that i do take the rough with the smooth, and I dont knock down 7671 just for the sake of it, it is a good guide as to working practice, but needs to be used with a big dollop of common sense at times.
Copper also 'flows' under pressure hence adding to the vibrations working on the screws themselves.Screws work loose I've lost count how many times I've tightened up terminals on inspections etc. The world around us vibrates with everything from the car going by, the stereo blasting, the plane overhead and screws will be screws and they will come loose.
