vad25
- Jul 6, 2009
- 60
- 0
Hello everyone.
Installed Low Profile Extractor Fan With Humidistat and when switch on power it started run straight ( switch for LS been switched off). Thought it needs time but after 1 hour steel was running. Disconnected permanent light, it stopped but no any reaction to switch when give power them. Went to Tool station and swapped fan for another, same problems.Today took another and same scenario. Connection has been made from lighting circuit with triple pole isolator( LS- switched Line,N-Neutral,L-permanent Line) .
Has anybody had that problem before, could you help me sort it out?
fan is from ToolStation Toolstation > Electrical > Fans > 150mm Low Profile Extractor Fan if link doesn't work code of it 54054.
Thank you.
Thank you.
