Extractor Fan
Mr T
Sep 8, 2009
91
Hi
I have a question about wiring a bathroom extractor fan that is to be turned on and off by a PIR
Here is what I have I would just like some clarification on the wiring
So from the Spur I have my ring cables so they connect into the supply side of the spur
I then need to connect from the Load Side of the Spur to the PIR - The PIR has a SL-L-N and Earth connections , so is it Line from the load to line on the PIR , N from the Load to N on the PIR and the same with E ?
I then need a switched live to take from the PIR to the fan , so here is my bit of confusion , if a 3 core and Earth cable is required from the supply side of the spur where would I connect my spare cable at the supply , Im aware all 4 terminals on the PIR would be in use but what about back at the Spur ?
Thanks in advance ?
Stephen
there would only be L and N at the spur, you will need a switch wire either from the switch or the fitting depending on which is easiest. You can get an isolator switch that has L, L1, and N (L1 = switched)
You don't need 3 core from the FCU.
You need a switched live from the PIR to the fan, to tell the fan to operate. You then obviously need a permanent live to the fan, a neutral and an earth. You can take these from just about anywhere, the FCU or the PIR. You could run direct in T&E from the FCU to the fan, then with a JB near the PIR, run T&E to the PIR and from the PIR, a single to the fan for the switched live.
Or you could run T&E to the fan, and 3C&E to the PIR.
Or T&E to the PIR, and then 3C&E to the fan.
I don't know where the PIR, fan and the spur are being positioned?
You don't need 3 core from the FCU.You need a switched live from the PIR to the fan, to tell the fan to operate. You then obviously need a permanent live to the fan, a neutral and an earth. You can take these from just about anywhere, the FCU or the PIR. You could run direct in T&E from the FCU to the fan, then with a JB near the PIR, run T&E to the PIR and from the PIR, a single to the fan for the switched live.
The Spur is to be mounted above a suspended ceiling , the fan is already in place , the PIR will be near the entrance to the door..
So am I right in saying it would be twin&e to the PIR so Live from the Load to Live on the PIR and N from the Load to N on the PIR then take 3 core from the PIR to the Fan i.e. SL on the PIR to L on the fan ?? If the Fan doesnt have a timed overun then am I right in saying you dont need 3 core ??
Hi just just thought Id post back some feedback in reference to the above
I connected these Extractor fans today and our wiring method was
From the Spur I ran a 2core&e flex to the fan brown to SL and blue to N and then a 3 core&e flex from the Spur to the PIR..
At the SPUR we connector blocked the brown from the 2core&e flex with the black from the 3core&e flex , the 2 blues were connected to N and the Brown from the 3core&e connected to L
I understand we wired this way to ensure there was only 1 cable going to the PIR due to them being a sod to wire into...
(So at the PIR we have the 3core&e flex ,firstly black (which is linked to the brown that goes to the fan & brown (which is in L at the spur) and finally grey , so am I right in saying that the brown will connect to L at the PIR as this is a permanent live from the Spur and then the black will be the switched Live as this is the cable linked through to the fan ?
Sounds like it will work, as long as the fan will work withoit a permenant live. May have to link that with the S/L.
Might have problems with the fan switching off while someone's in the bath.
Sounds like it will work, as long as the fan will work withoit a permenant live. May have to link that with the S/L.Might have problems with the fan switching off while someone's in the bath.
I linked out the L and the SL at the fan
I hope you identified the black and the grey with the appropiate coloured sleeving : O)
