I've just come across an interesting piece in the Spark magazine regarding the installation of your average bathroom fan. Now we are all aware of the need for triple pole isolation in the circuit on fans with a timed overrun. The interesting part is most manufacturers state that their fans should be protected with a 3Amp fuse, or they will not accept responsibility for damage resulting from a faulty unit. Now this puts us in a predicament as most are wired off the bathroom lighting circuit which is invariably protected with a 6Amp breaker at the board. This leaves us with no choice but to fuse the bathroom lighting circuit down before the split to 3 core, as the permanent and switched lives cannot be fused seperately, so where are we supposed to squeeze this extra piece of equipment in? The alternative being a 3Amp breaker at the board, easy enough on a new build, just a seperate circuit for bathroom lighting. Not so clever on an existing installation, as many phone calls would follow for overload trips!
Your thoughts?
Your thoughts?
