- Feb 27, 2008
- 11,018
- 0
Has the Rcd tripped any other time when lawn mower is not going?
Added a diagram in the hope that someone can check out the theory. It sort of makes sense on paper - but can't put any figures on it for the real world.Don't know how I've missed this post - some interesting points!Not sure if this approach has been covered - and it's something I have a hard job to wrap my brain around - but I reckon it's all down to transients.
As far as I can see these faults always seem to be associated with motors. As these are brush type motors I can imagine that current is being interrupted at the commutator resulting in some high frequency transient voltages - much like an ignition system on a car (points = commutator, coil = motor windings).
Assuming the motor is double insulated and there is no earth fault, then the neighbours RCD may have an instantaneous difference in current between live and neutral (storage via the motor winding inductance?) - but over a cycle it may even out - i.e. fault not there long enough to trip the RCD - and symmetrical.
As the earthing is PME it is possible that some of the transient may find it's way through the RCD coils to appear on the Line and Neutral.
At the OP's house neutral terminal the transient now has two paths to an appliance. One via the neutral winding of the RCD - the other via the cpc. The transient on the neutral would be attenuated due to the induction of the winding. However the transient at the CPC - assuming a high impedance path to either live or neutral via cable capacitance or appliance resistance - would not be attenuated, and would also be phase shifted to the neutral current due to the induction. So now there is a possibility of a differential and non symmetrical current existing - maybe enough to trip the RCD.
Am I barking up the wrong tree here?
Perhaps it's worth checking if the strimmer suppressor capacitor is fitted- or whether there is any radio interference from it?
