Your set up is correct. I often look there or remove a built in oven to check this whilst carrying out Periodic inspections. Far to often i find the ign circuit directly connected to the supply with a 40a breaker as the only protection.
Hi Special Location, Thanks for clarifying the process of calculating diversity for me.
Although as you say, Mr Sworld
Hello Mr S'Good point Spec's. However I read the OSG's Table 1A as individual items per circuit.From the third paragraph on p84:
The current demand of a final circuit is determined by summating the current demands of all points of utilisation and equipment in the circuit...
So I'm reading that as each individual item has it's own diversity calculation.
However the first paragraph on p85 reads:
The use of other methods of determining maximum demand is not precluded where specified by a suitably qualified electrical engineer
So that covers your method.
I agree that it can be more sensible to consider a seperate hob and oven as a single item, it's just that i love my safety factors!![]()
Mmm, I wonder if I
No chance m8 if Welshy's about...He'd have it out of your hand before you can say "30ma RCD"!!:O]
Oh by the way DCM...
when you get this new cooker working...
Were ALL coming round for Sunday roast!! ]![]()
That INCLUDES steptoes horse!!!!; ) :^O :^O:^O
If cooked correctly.... I bet slipshod Could!!!- You can't eat Steptoes Horse.
:^O
Quite!I must also say that probably 80% or 90%+ of oven/hobs I have worked with have actually been either...1) Electric oven with seperate Gas hob (only ignition needed).. or...
2) Combined single freestanding cooker, (oven + hob).
So the actually reality of this diversity calculation with TWO high power units doesn't actually come up very often....![]()
WUSS!!! Ceramic & halogen all the way............Quite!That is the whole thing with regulations. They aren't hard and fast. Interpretation is all!
Admittedly as a (very) keen cook I wouldn't go anywhere near an electric hob, even the induction versions. Gas every time for the hob. Electric fan for the oven. :^O
Nahhhhh!WUSS!!! Ceramic & halogen all the way............ Easier for the missus to keep clean, too:x
Pillock! You`re suppoosed to use the UPLIGHTER??????? Duh. :^O :^ONahhhhh!I tried boiling an egg on me halogen light!
Kept fallin off the ceiling!!!
:^O :^O:^O:^O:^O:^O:^O:^O
Doh!!!Pillock! You`re suppoosed to use the UPLIGHTER??????? Duh. :^O :^O
