Fire Alarm Isolator
Sorry just had a quick look I thought the circuit board was part of the switch. Second look I see the switch is below. I see its sold by a fire alarm company so probably should be OK. Are you thinking of buying one?
Fitted similar a few times but mk version still that sort of money.
On the fire alarm course I went on I think they suggested this was the only way to comply or possibly a fire alarm switch fuse. I will have to check the fire regs when I'm home.
I don`t like the fact that the fuse is rated 6A, yet the keyswitch is only rated 4A - wouldn`t think it compliant, tbh.
Plus, initial look at the PCB seemed to suggest the cpc and N were interrupted by the keyswitch - but we obviously can`t see the tracks on the rear of the PCB
Why would it need a PCB I ask ?    A keyswitch  + fuse   would do the job .
Someone does a keyswitch one , similar to an Emgy test Switch with a red plate .
It was always an unswitched spur for years.
No expert and don't do this sort of thing often but...
Wouldn't have thought the rating would be too much of a problem, how much do fire alarms draw? And aren't they not always fused straight away inside?
And if it's a isolator it's got to have a clear indication of on and off a key switch and a unswitched fused spur don't provide this. You could argue to MCb or fuse does this but is there a requirement in fa regs for it to be local?
We normally use a MK grid with fuse and DP secret key, if theres room we make it a double box and 3 module grid and add a power on neon as well (generally on new installed, where as on existing swaps you have to fit in the existing single box)
Fitted one a few weeks back very similar
I think it's a bit of a rip off for the money . But there doesn't seem to be many alternatives!
