sounds like non-sense to me, unless they are trying to insist it should be a red coloured switch, but I don't recall anything that makes that compulsory.
every panel I have seen in larger buildings and small commercial has been on it's own cct with fused spur (unswitched) located close to panel so it can be isolated if necessary for maintenance work. Only other point is that the supply cable should be fire rated I think - not sure if that applies to all circumstances?sounded like nonsense to me either. dont do fire alarms so couldnt say but it does look like they are trying to create unnecessary work
Normally key switched rather than unswitched.afaik, Fire alarms are supplied in a FP cable on own circuit with a red unswitched spur. I'm guessing the red plastic must be fire retardant?? or do they just join the FP's direct through in the box?
I can confirm tomorrow as fire company are on site this week.
quite correct my bad!Normally key switched rather than unswitched.
