Fluke T5-1000
SteveT
Oct 18, 2010
406
Just bought a brand new Fluke T5-1000 on ebay (UK spec) for
Looks like a good deal, we have it on our site at 89.00 ish plus the vat.
A proving unit is a stand-alone device; which will generate the voltage necessary for "proving" your "voltage-indicating-device" is working. It really doesn`t care what is touched to its terminals.
A good little tester, i have had mine for around 4 years,
I like a voltage tester with an LCD display, so i can see exactly whats present
A good little tester, i have had mine for around 4 years,I like a voltage tester with an LCD display, so i can see exactly whats present
Defo know what you mean mate. I've got the cheaper fluke with the LEDs that show what voltage is present but I'd rather see a display showing exact voltage like yours does. Which is why I'd rather use me cheapo
Now I`m afraid I`m on the "other bus" here....
I don`t NEED to know exactly how much voltage is there - TBH I wouldn`t be "testing" for voltage unless I already knew what ought to be there. If I do require a voltage reading, I wouldn`t use a voltage indicator, I`d use the MFT on voltage range. I can`t see the reasoning in having a piece of kit that has "added facilities" I`d never use / rely on.
KME
I'm with KME on this.
Voltage indicator for just that indication, for safe isolation primarily, or very basic fault finding, trip gone (when it's a long way from me), fuse blown etc.
Anything more complex, multi meter / clamp / mft comes out if I need to "measure" anything.
I will confess however to realising this after getting a KEWTech 1710 & realising that I don't need the voltage readout!
i dipped my t5 1000 into my proving unit today as i was thinking about this thread and i have only ever used my proving unit with my martindale.
the result was 857V DC.
does this tester trip out rcd's when testing L-E?
also, what size cable can you fit between the prongs? would it fit 16mm tails for example?
Now I`m afraid I`m on the "other bus" here....I don`t NEED to know exactly how much voltage is there - TBH I wouldn`t be "testing" for voltage unless I already knew what ought to be there. If I do require a voltage reading, I wouldn`t use a voltage indicator, I`d use the MFT on voltage range. I can`t see the reasoning in having a piece of kit that has "added facilities" I`d never use / rely on.
KME
You beat me to it KME!!!
