i wish you wouldnt post photos of my electrical installations i had a right nightmare to get that installation to that standard :slapI found this gem on an EICR of a local nursing home. It had been done 5 years previous and I can only pressume was missed.
The cover on the meter was originally on before the photo.
Good job there was no seal on the meter or cut out then :innocentWish i had time for all that. Just whipped them out. No danger.
Wouldn't the "ideal" be that a REC isolator gets fitted? So meter to REC = theirs / REC to DB/CU yours to mess about with as you like!Just asking for learnings sake, in the absence of Amelie, and a DNO guy, where does the DNO's responsibility stop? I understand that we are not allowed to mess with the cutout and the meter, but what about the tails coming from the meter to the DB? Obviously they have to terminate into the meter....
What is the legal stance on it? Im not on about what happens in the real world, but what should happen if we lived in an ideal world
There is even talk of the meter gibbon checking the connections in the CU after the meter change " if he thinks it appropriate having carried out a risk assessment "I believe the tails leaving the meter are the consumers, so the DNO will not be interested. There are ongoing discussions about the responsibility that the consumers connections at the other end of the tails can be loosened when a meter is changed (don't ask me to quote what discussions, i cant remember)
