Hi All,
From my post about the welder nameplates, you can see that the one maker recommends a T40A fuse. What the heck is that??????
I have tried looking, and it is apparently a "fast acting" one. This is quite the opposite to what conventional thinking would thing would be suitable for a 400A welding set.
I found a curve for the type of fuse here; http://www.cooperindustries.com/content/dam/public/bussmann/Electrical/Resources/product-datasheets-b/Bus_Ele_DS_1029_JJS.pdf
From what i can see of the curve, the things are even more touchy than a "B" curve MCB [unless i have misunderstood the graph]
Does anyone know what the MCB equivalent to one of these fuses would be??
Has anyone any experiences of welders on "B" curve breakers?? Conventional thinking would have you fitting a "C" or even a "D" so long as Zs was low enough. but i have never had any problems with one on a "B". have i just been lucky??
Anyway, how do they get away with using a "fast acting" fuse... Why does this not simply blow due to the inrush current. As i say, looking at the chart they are even more touchy than a "B" curve....
john..
john..
