sounds good. you can also get 5A fuses easily
You wouldn't feed a 3KW heater with 0.5mm flex. 0.5mm flex can only carry 3A, you'd either have blown fuses every time the heater was turned on or melted flex.Surely you'd select the fuse rating relative to the cable size rather than the load?If I fed a 3kW heater with 0.5mm flex would you fit a 13A fuse?
That's just arguing for arguments sake. Might as well apply the same logic to every thread and assume not one part of the job is right and basically make the forum completely pointless.Surely you'd select the fuse rating relative to the cable size rather than the load?If I fed a 3kW heater with 0.5mm flex would you fit a 13A fuse?
