Customer has a house with and old consumer unit with semi enclosed wire fuses. Earthing is TT with a 100ma RCD. One way from CU connected to 30A fuse is connected to 2.5mm three core SWA cable to garage 20m away. There is bonding to gas/water in place.
In the garage is and old style metal CU with four ways also with wired fuses (each of 5A rating) one way is connected to the garage internal lighting circuit, another for some sort of security camera, another for a bunch of PIRs/security lights on the outside of the garage and another for some garden floodlights. The customer would like to keep each of these circuits separately fused for some reason.
There is no extraneous metalwork /water pipes etc that I can see in the garage. As far as I can see earth return for the garage is via one of the cores of the SWA and possibly the armouring.
He wants me to add a new radial circuit in the garage to serve one double socket for a freezer and for the odd power tool.
I
I
