Good Morning All
Thanks for accepting me, hope I can tap into your collective knowledge.
I have a 1950’s house with a detached garage that runs parallel to it with a 1 metre wide path between it.
currently the supply to it is as follows....
the power supplies an electric roller door, 2 single sockets, 2 double sockets and 4 led strip lights. Have a tumble dryer out there but no welders or big equipment, I just store the scooter and garden stuff in it.
I had a few doubts about the flex being ok for the job so started reading up a bit, before I ask around for a part p registered electrician to come out, am I just over concerned?
didnt think twin and earth flex should be run to an external building?
Although the cable is less than the 3.5m high I seem to read about, it’s a footpath accessed by only me, should I raise it?
would it be beneficial to change the old wire fuses for something more modern
Thanks very much for your time and stay safe
regards
Steve
- RCBO 32 30ma in fairly new consumer box under the stairs.
- twin and earth flex coming out of house approx 2.8m high above path then suspended catenary and into garage fuse box.
- old metal fuse box with wire fuses in garage.
regards
Steve
