Aico make a relay base (Ei128R) that you could wire an external sounder through
So you can wake up all the neighbours when a spider crawls into the detectorsAico make a relay base (Ei128R) that you could wire an external sounder through
Only if the spider is on fire OR F hot as heat detectors were suggested, were they notSo you can wake up all the neighbours when a spider crawls into the detectors
Got a photo of a burnt spider in a photocell somewhereOnly if the spider is on fire OR F hot as heat detectors were suggested, were they not
Yes they do, it’s reciprocalSo the alarm goes off in the ops garage, linked to the neighbours house
Does the neighbour have a key to the garage?
I've got one of a mouse that decided to have a mooch between two phases on a Dorman smith loadmaster boardGot a photo of a burnt spider in a photocell somewhere
You clearly put a very lowly value on safetyI don't agree.
I checked the reviews, of the 30, 2 did not like them, 1 was because they couldn't press the silence button, and 1 who had to change the battery. There were also 2 who said they do not comply with Scottish regulations, but the seller does not say that they do comply to Scottish regulations.
Those that got them then added more, did not report a problem when they read the manual (Said it took a couple of tries, often people do not read manual correctly.) Smoke alarms by default have no user serviceable parts other than the battery, so yes if it fails change it.
I would have no problem installing them here if I needed them. (I changed all mine 2 weeks ago, as they were slightly over 10 years old)
took a while to find this picure...I've got one of a mouse that decided to have a mooch between two phases on a Dorman smith loadmaster board
One eye on one phase and the other on a different one
