Hi everyone
Wondering if you can help. Im a fairly useless DIY idiot trying to figure out what is wrong with a Grasslin Quartz Mechanical Clock. Its hooked up to a Eurocombi sx20 mffice.
My problem is that i cant make it tick. Ive bought a replacement clock and fixed it up following the old wiring set up and it doesnt work.
There are 5 connection - i have a brown wire going into 1, blue going into 2 and a red going into 3 and 4.
The boiler works fine if its set to permanently on and also if its on the timer at the correct time. the problem is the clock doesnt move!
is there an internal battery or soemthing that i am supposed to change or is it hooked up to the mains?
Could there be a problem with the original wires?
Many Thanks and sorry for the total lack of expertise.
