Blue Fox
- Dec 12, 2008
- 351
- 1
Hello all,
The father in law lives in a council house. They have just had the gas fire condemned so the council has fitted a new combi boiler and all new central heating for him.
However when I popped round there today he showed me what the electrician had done. First I asked if he had a certificate which he didn't but though "oh its probably gone straight to the council".
I'd already primed him to ask the guy if he was part p registered and apparantly he said he wasn't, so I thought "I guess if its council it could easily be done through the building regs for free for the council".
Then I looked at what he had done, at the bottom of the boiler there are 5 or six copper pipes coming out of it in a row, to these he has fitted bonding straps, but instead of linking them with a bit of cable he has used the "tail" of the strap and clamped that into the next clamp. Is this ok?
I would never have thought of it and always use a bit of cable? Also the original boiler was in the chimney breast in the living room behind the condemned gas fire but has been moved upstairs to the airing cupboard where the cylinder once was, I don't know where he got the supply for the boiler from but guess it was the sockets ring on a spur as there is only a single 2.5 going to the controller and he has put a socket next to it as well at the father in laws request but I didn't see a FCU at all.
Also he has run a 10mm earth to one of the pipes going into the boiler and what I think is a 4mm to the rad in the bathroom - its certainly no bigger than 4mm.
Neither of these cables, could we find the other ends of! But when I asked where the main earth bonding was the father in law didn't really know what I was talking about so I got him to show me where the stop cock was and no sign of a main bonding.
I also asked where the rcd was as the house still has rewirable fuses which was met with confusion so after I explained what I meant he said oh no theres nothing like that!
So my points are:
1. Is using the tails of the earth straps ok? - I would say no.
2. Surely the lectrician should have fitted a main bonding to the water pipe where it enters the house as part of this job? - I would say yes.
3. Surely he should also have fitted an rcd to the circuit? - I would say yes
Going to go round there over weekend with tester and check a few things and depending on your opinions guys, and my test results, may take this further with council.
So my points are:
