johnb2713
It will help you with the 50A rating of the connectors, increase the voltage / decrease the current.So I need them to be series connected?
Ah ok, so it can stop itself blowing up. LolThe inverter will control the output.
Thanks John, I really appreciate your help. My head got really messed up with all this.It will help you with the 50A rating of the connectors, increase the voltage / decrease the current.
Sorry, another question. There are lots of things that come up as a fused isolator, could you show me the best thing to use?Thick cables go off to fused isolator, then solar cable into the inverter, Solax in this case, I'll see if I can find a
Binky has one he recommends, I'm sure he will be along shortly once he's had his full English and a mug of tea.Sorry, another question. There are lots of things that come up as a fused isolator, could you show me the best thing to use?
Thanks.
It's quite a confusing topic, I am far from expert in the field of batteries. I buy kits of parts from my fave wholesaler, so I get everything I need and follow the instructions.Sincerely thanks guys. I know I sound like a moron not knowing what you guys probably all consider the basics, but I'm trying to learn this stuff, and thanks to you guys, I have a lot more understanding now.
Excellent Binky, thanks, I'll Google Keto fused isolators. I think I'd agree with Solis on this one, any protection I can give the isolator or anyone around the system has to be good. Thanks yet again for your help.It's quite a confusing topic, I am far from expert in the field of batteries. I buy kits of parts from my fave wholesaler, so I get everything I need and follow the instructions.
In the video you may notice a small white box to the left of the inverter, that's an isolater for the battery rather than a fused isolator, Solax don't seem to fuse the battery side, Solis do. Personally I think it's good practice to fuse the battery side as that seems popular with other battery systems such as your car or caravan. Solis supply Keto fused isolators with fuses in +ve and -ve lines. I like Keto because its a good solid piece of kit, but there's plenty of others available.
Hi Michael, I haven't seen that in my manual, are we talking about the same inverter? Mine are H1 6kw Hybrids.I looked at a Fox ESS until I spotted in the spec that it needed an HV battery arrangement.
Not your run of the mill Hybrid Inverter, the majority being "48V".
Two Pylontechs in series will work to give "100V", but I only have one, and "48V" isn't enough.
it's on the data sheet if you have that to hand.Hi Michael, I haven't seen that in my manual, are we talking about the same inverter? Mine are H1 6kw Hybrids.
