PeatBog
I have recently fitted AICO Ei160RC series of heat and smoke detectors in a house. The lady of the house is deaf so the system includes a hearing impaired unit which has a strobe and vibrating pad.
The client has now asked if I know of a "Hearing impaired" security alarm system.
I don't know of such a system but presumably I could take the output signal of most/any security alarm system and wire it into a relay which could then actuate the AICO Ei408 Switched Input module. Which would set off the Smoke/Heat alarm system including the Hearing Impaired kit.
The EI408 triggers alarms when its contacts are closed.
Obviously the relay would be 12vdc on the control side but switching 230v of the heat/smoke system.
Any comments?
Any comments?
