not quite - another spark could I&T on behalf of the council, but only LABC can sign off someone else's workUnless it's arranged through BCO then all of a sudden they can?!
:|Surely you are all missing the point.The owner CAN pull the wires.
Just as long as the electrican tells him exactly where and what to run.
Then the electrician signs the DESIGN part of the certificate, the owner signs the CONSTRUCTION part, and the electrician signs the TESTING part.
What am I missing?????
:innocent :innocentRemember Boys & Girls... Just As the vet says...A DIY PERSON CAN STILL REWIRE THE WHOLE OF THEIR HOUSE IF THEY SO WISH!!!!
so if owner signs construction, then he also second fixes?Surely you are all missing the point.The owner CAN pull the wires.
so if owner signs construction' date=' then he also second fixes?[/quote']There is nothing in wiring regs to say the same person does all the work, design, construction and test, indeed wiring regs assume they are done by different people.
But what about large firms of sparks? are you sure it is always the same spark that second fixes every job as first fixes it? what if a differewnt spark second fixes it? you wouldn't batt an eylid youd you? so why question in this case? If in doubt, both the owner and the spark sign for construction.
The point I was trying to make is, there is nothing wrong with different people doing different bits of the job. So what's wrong with the owner first fixing and a spark second fixing and testing? Nothing as far as I can see, certainly not anything in wiring regs to stop it.
Or is it specifically not allowed in Part P? We don't have part P up here so I'm not subject to that so don't know all the limitations it might have.
I guess I'm a sort of "show me where it says I can't" sort of person, rather than "show me where it says I can" A bit like comparing half full with half empty.
Bang on the money there, Pro. In the automotive R&D environment we had a golden rule about engineering a vehicle or system to meet legislative requirements - "unless the legislation says you cannot do it, then you can"There is nothing in wiring regs to say the same person does all the work, design, construction and test, indeed wiring regs assume they are done by different people.But what about large firms of sparks? are you sure it is always the same spark that second fixes every job as first fixes it? what if a differewnt spark second fixes it? you wouldn't batt an eylid youd you? so why question in this case? If in doubt, both the owner and the spark sign for construction.
I have yet to come across a customer that does any of the donkey work correctly. Chases are never deep enough, boxes are on the wonk, cheap materials supplied, cable not run off the drum correctly etc. Those kind of jobs end up costing YOU money. I wouldn't give those type of customers the steam off my urine I'd fan it away from them.I never saw the programme so couldn't really comment. With an understanding electrician brought in at the design phase I would have thought there was scope for reducing the price.For example if you designed installation and homeowner did the donkey work of sinking back boxes, running chases and helped pull cables then it could be win/win? Doubt you get a lot of satisfaction in chasing or lifting floor boards?
