Hi Dave and Sharpend,
I can explain the reasoning behind the complications:
I do not wish to have the Thermal Store constantly heated 24/7 365. So under normally conditions the thermal store will be cold.
If I want hot water I need to press the hot water button or boost button. I do not wish to walk to the thermal store and climb into the airing cupboard each time I want hot water.
Therefore I would like to have a hot water button on a 3 channel controller upstairs and also a hot water button on a controller should I be downstairs.
On the other occasions we I decide to just leave the upper part of the tank warm for DHW for a few weeks for example I still need the facility to switch this off without having to climb into the airing cupboard again to get access to the tank.
Hot water is controlled by what is called a economy stat located near the top of the tank. But this economy stat has to be controlled by something. Therefore it has to be told to come on and off when needed. That is why I think having a 3 channel controller to do this is the best approach unless there is another way??? The "DHW button" on the programmable controller when pressed would then send a wireless signal to the receiver at the tank and the receiver would be wired to switch on the economy stat, switch on a flow switch and switch on a circulating pump for the heat exchanger). And there would also need to be a power supply sent down to the oil boiler to heat the water in the TS upper section.
That's the reasoning behind having the Qty x 2 (3 channel progammable stat)
Programmable stat (located downstairs)
output channel 1 = (DHW)
output channel 2 = (Central Heating downstairs)
output channel 3 = (DHW boost 1hour)
Programmable stat (located upstairs)
output channel 2 = (Central Heating upstairs)
There is already a built in 2 channel controller located on the store itself (comes with the DS-10 Thermal store). There is nothing I can do about that it comes with the package
The purpose of the 2 channel in built controller is to control the tank stats. There are 1x tank stats at the top called Economy stat and 2 x buffer stats in the middle of the tank called buffer stats.
Econ stat is for DHW
Buffer stats are for central heating and DHW
Therefore I need a way to control the 2 channel built controller which in turn will then control either the Economy stat (DHW)or the buffer stats (CH).
Please let me know if I have justified my reasoning? Please suggest an alternative way to control the DHW without having to go near the Thermal store i.e the comfort of my livingroom!
Please see attached my diagram showing the layout of my heating system.
Thanks again guys
View attachment Basic Heating Control Overview.doc
