andy8758
- Oct 20, 2008
- 48
- 0
Anyone help me with a problem with external lights switched with a PIR? Customer wanted 3 installed, done. No problems - everything tested OK, lights worked with CFL energy saving bulbs requested by customer. Then the lights started to fail - seems to be a problem with the PIR switch. Spoke to supplier who tells me that the failure is due to my use of the CFL energy saving bulbs which the PIR cannot handle.
I knew that use of CFL's with some dimmer switches causes problems, but was unaware of this conflict with PIR's. Have to say that always previously used halogen bulbs or candle bulbs in outside lights with PIR's.
Can anyone explain to me - is supplier right about this fault, and why?
Many thanks, in ignorance, Andy headbang
