right, there is a 2-core 4mm swa leading from the CU in the house to a chalet 5m away. The chalet has two circuits, lighting on a 6amp breaker and two socket radials on a 16 amp breaker.
is it okay to use the steel sheathing from the swa as the earth?
should be on a 20 amp breaker at the house right?
