electrizion
- Aug 1, 2008
- 51
- 0
Doing some repairs at a school after a P.I.R.
One of the problems the report bought to light was the failure of a 61009 rcbo to trip when the test button is pressed.
The rcbo feeds some socket outlets in a classroom into which are plugged four pc`s and 4 crt monitors. To cut a long story short unplug any two of the monitors or pc`s the rcd operates correctly plug them in again and it fails to operate when the button is pressed it chatters but will not trip.
The wiring is old 7.029 no cpc conduit system ( as is most of the school)
The ELI is within spec the rcd operates within spec under test.
I have replaced the rcbo with no effect, connected the ring to a different rcbo and phase still no effect.
Any ideas please
Any ideas please
