toontoonizer
Active member
- Jul 21, 2020
- 29
- 0
I wish I was growing drugs then I could pay for this bill.300kwh per day, ouch, that’s nearly what we use per month!
you growing drugs ?
seriously that is huge consumption- what are you doing?
Seriously, we have nothing that could be drawing that kind of massive consumption. No machinery, no motors etc.
The main house is quite large (6 bedroom), 3kw immersion heater (only for hot water and only used when there is no oil), oil fired boiler (when we have oil), small 300w underfloor heating circuits in 4 bathrooms, that are set to 21degrees. We also run a couple of 2kw oil heaters for 1 or 2 hours a day and normal kitchen appliances, washer, dryer, stove, kettle, microwave, oven. Lights are all LED.
The annex is basically another house, 3kw immersion heater (which is always on, but only heats when water drops below temp) underfloor heating in 5 rooms (totalling 4kw + .8kw + .5kw +2kw + 0.2kw if they were all on at the same time), they are never on at the same time and are set to 20/21 degrees). All LED lights, normal kitchen appliances but we have a boiling water tap which is 1kw always on. There is a wine cooler which is 1kw, coffee machine, oven, microwave oven.
I've done some basic calculations and I can't get up to 300kWh. It just doesn't make sense, even though there are effectively two abodes.
This faulty kit would have to be drawing 100kwh a day at least. I think we would notice something like that!Or is it possible that a comprehensive test of the whole installation, inc all final circuits has not been made..
and you do have some faulty kit somewhere drawing far more than you thought?
Hence, more load more volt-drop!?
On an earlier post I think you said you have no electrical certificates for any parts of your installation..
Have you asked your electrician verify the condition of all circuits?
On the balance of probability you would have to assume the New-Meter is good?
:C
I would have to agree re the meter but I can't identify anything else that would be drawing this kind of consumption. The meter is emitting an audible buzzing noise. It's also shown solid red lights when we have had power going through it. Usually the 1000/kWh import light is flashing non stop, once a second.
Today, no one was at home for one hour. We consumed 10kwh while no one was at home.
I've enclosed a pic of the meter, that last digit doesn't happen to be a decimal point does it?
