Hi All, newbie alert so please forgive me if I got the wrong forum area.
As per title, I'm trying to Hi-Lo dim a bank of outside LED lights.
I'm encountering that finding a stand alone Hi-Lo PIR suitable for LED's is virtually impossible, so thinking about creating my own solution within an IP enclosure as per image attached. Pleas excuse the crude drawing, I was trying to make sure my cable runs were do-able more than anything else!
Essentially what I'm trying to do is :
I think this will work, my main question is, is it ok to have the dimmed 20% supply connected to the supply that will go 100% when the PIR activates. Will the 20% switch mess with the PIR output and vice versa will the 100% output from the PIR mess with the dimmed supply? I can't see why not, but wanted to see if you guys had a better way of doing it.
Thanks.
Steve.
- On sensing dusk, the lights will come on via the dimmed circuit if the timer is on.
- The reason for the timer in line with the dusk sensor is that I want lights to come on when it gets dark, but I don't want them on all night, so will probably time them out after 11pm.
- The dimmer is in line with the dusk sensor circuit so that under normal conditions the lights only come on to say 20%.
- The dimmer will be a trailing edge type suitable for LED's.
- There is then a separate PIR with a timed "on" period contained within it so should it be activated, the PIR will then put full voltage on the output side of the dimmed supply and the lights will go to 100% before returning back to the 20% setting.
- There is also a 2nd PIR at the other end of the area I'm lighting to serve the same purpose.
Thanks.
Steve.
