Thank you for the continued help...I have made it complex, but when it is your 'forever home' (a new build) I have thought long & hard about how things can work to cover as many eventualities as possible.
It is indeed having the timer and switch/PIR working independent of each other. So the timer controlling it for a manual on & off periods during the day (for our normal commute in Winter)...then ALSO having the option of PIR controlling it separately (but with the option of disabling it) for out of hours use in Winter. Then the ability to turn 'off' the timer and turn 'off' the PIR for when we are on holiday/summer....or a combination of all of the above.
The PIR/switch combo is in place and working as we want it, I am just asking for the Electrician to insert the timer function as per John's sketch.
Our electrician captured requirements, installed wiring & billed us for it (incl the installation of a timer alongside PIR + Switch, detailed in quote). It was his suggestion another Electrician might have ideas on how to get it to work that had me excersising this option to seek a 'fresh eyes' approach vi this forum.
