- Mar 28, 2008
- 14,328
- 975
Whilst in the process of disconnecting & removing some old cables supplying downstairs lounge sockets this week....
I found what appeared to be a ring leaving the CU, 2x T&E onto one 30amp fuse,
tests indicated it was either a broken ring or two radials! ?:|
Disconnect one cable.. suss out which sockets are dead, remove some sockets, lift some boards,
(that have obviously been lifted previously), and find this hiding.....
Is it the "other half of the ring" or "the end of the other radial", ?:|
Two ends make me think it was once a joined up ring?
Look close at the nice glowing voltstick... Yes its live when fuse put back in!!!
Who puts a 20amp Double Pole switch under the lounge floor...
with a taped up open end.. both of which would have been live when the sockets fuse were on!!
The only good point was you did need a tool to access the joint!
tools required can be seen on first photo! ; \ :^O:^O:^O
I did think at first it was one of Nicky T's famous tape joints...
But obviously I was mistaken cuz...
a) it wasn't on the lights, and
B) don't think even N.T. lets his joints fall apart as easy as this one did.... ; )Guiness Drink
