Hi, quick question often when installing consumer units. The guy i work with just knocks out a hole in the top of consumer unit to fit the main tails and bonding. Sometimes these are the square holes for example a mk board. Is this an acceptable means of installing tails? or can these holes be filled with something i,m sure that the top of a consumer is supposed to be IP rated as is the bottom.
