- Dec 25, 2011
- 5,468
- 78
Say you have a 16mm hole but you want to put a 20 in or a 20mm hole and want a 25 hole. Yes, I know cone cutters / step drills etc but they go blunt. Starrett have the "OOPS" allowing holesaws of two different arbor sizes to be used but no good for the smaller sizes:
But for using two of the smaller sized arbor cutters together........I think I'll call mine the "FOOKIT". First, get yourself a 1/2" UNF 20tpi x 2 1/2" long bolt and cut the head off, file neatly and de-burr:
Then screw on a couple of Starretts:
Job done. Needs a 13mm chuck so I'm going to turn the plain shank down to 10mm so I can use in my right angle drill too.
