It appears easily enough wired as this model only has 3 wires ( blue , brown and earth ). It looks as if it would not have enough flow through it when it is open. The ball does not come away from the seat of the valve very far when in the open ( normally ) position.
---------- AUTO MERGE Post added at 20:03 ---------- Previous post was at 19:50 ----------
What I am trying to say is , do these vaves ( 28mm) allow much of a flow?
---------- AUTO MERGE Post added at 20:06 ---------- Previous post was at 20:03 ----------
Or can I use a normally closed valve ( much cheaper ) , although it does need to be open for the majority of the time, therefore needing to be energised all the time. , against the spring.
