Hot tub amd electric shower.
Paul ingleby
Sep 8, 2020
Hi, can i run a 32 amp hot tub and a 9kw electric shower off of one 40 amp switch on my circuit board, i was thinking of using 6mm2 cable for this. Any advice please?
Keep the local fire brigade on speed-dial if you do. If you read the manufactures instructions for each product you should find guidance to the type of circuit required for each. I would think the words; dedicated circuit, competent person and in accordance with current wiring regulations BS7671,  will be somewhere in both. Your suggestion is lacking most of them.
