I'm going to be putting a supply in for a hot tub. Something I haven't done before. I planned on putting a 6mm twin and earth from the consumer unit to an external rotary isolator, connecting the cpc straight through to a SY flex which will run to the hot tub. However, the company fitting the hot tub have said the Earth needs to be separate on an earth rod. So the cpc of the twin and earth terminates in the back of the isolator enclosure and the cpc of the SY flex connects to the earth of the rod. Is this correct? I've looked in the regs book but cant find anything on it.
Any help would be much appreciated.
