Some really interesting discussion here, it does seem like the consensus is that a full rewire is needed though. I will make sure to check the board used and avoid the RCD's. Anything else I should be looking out for or requesting in a quote?
The only thing that will help is if you have a spec for each contractor to quote against....
go room by room and write down what you want
EG
LIVING ROOM
6 x double sockets
1 x TV point
1 x BT point
1 x pendant
2 x wall lights
1 x double light switch
1 x smoke alarm
also think about if you want plastic or metal finish accessories
and if you want them to arrange the plastering of any chases
Frankly cant be arsed finding the numbers but
cicuits shall be designed and installed to minimise inconvenience.....dua. RCD HALVES inconvenience and does NOT minimise it
a fault on one circuit should not influence another,,,,,,,..........dual,RCD turns half the board off, so it has influenced other circuits
Quod Est demonstrandum
Ipso Facto
spaghetti carbonara
There's (apparently) also that the RCD shouldn't protect circuits that exceed its rating and the the max leakage of combined circuits shouldn't be any more than 9mA (I think)
