Hi all,
What you think of this....Would you be happy with this???
I am doing a favour for someone, that, amongst other things involves laying a 70 meter long submain across a garden.
Now, this submain is five core 25mm. You stick a fork in there and you will know it.....
I decided that the cable would run in four inch duct Ridgiduct, and that from ground level to the top of the duct would be 450mm. Ideally, I would have liked deeper than this, but for archeological reasons this would not have been possible...
Anyway, obviously, even with an excavator it took all day to do this, and there had to be an archeologist there too [at vast expense] to have a look at the hole being dug!!
So, i was busy installing ducts and other stuff at one end of the trench as they slowly plodded off the other way. Today though, i find that as soon as my back was turned they had started to come up towards the surface.... Reason for this being that, the last 25 feet of duct will have to be dug by hand, so they obviously told the digger driver to "come up" as it were, to make things easier for them digging the remaining bit.
They thought i would not notice.... I did a bit of a survey today, by pushing a thin steel rod into the ground along the run of the duct...
You see, they were NOT happy that i said it had to be at least 450mm down in the first place, and they think that i go "over the top" as it were, and just like to waste money. [i hear frequent references to Isambard Kingdom Brunel from them]
Now as it turns out, a fair bit of this duct is only about a foot down..... I am NOT NOT NOT happy with this at all. I know that there are no regs that specify any particular depth across gardens, just the "reasonably foreseeable bit" But i am not happy about a cable that size [duct or not] only being down a foot to the top of the duct....
What say you all?????
john
john
