DonkeyDong
- Mar 14, 2008
- 218
- 0
He guys,
I dont tend to do much domestic work like this, so could do with some advice?
Been to look at a job, where the client has had an extension built, they have installed the wiring themselves (still totally visible). Consists of one ring, and one lighting ciruit.
They want it finishing off/connecting/signing off.
The LABC application was done in 2006, but they are only just getting it plastered. Cabling is mixed colours.
Existing CU is a wylex rewirable which is full. They potentially want an additional CU for this extension, or the existing CU replacing. Water and gas is in close proximity. The head is on the outside wall, the CU is on the inside of the wall at ceiling height in the kitchen, above the sink where the water comes in. Gas is also just outside next to the head.
Now, which Regs would this need to be wired to? 16th or 17th?
The work will consists of two parts:
Consumer change/additional
Second fix for the fittings
How long would you estimate?
Many thanks,
D.
Many thanks,
D.
