paul copeman
- Jul 11, 2011
- 54
- 0
two quick questions could you help pls
i have put up an emergency light but i want it to run as a normal light i.e not power up when i turn off the switch
there is no permanent live so ive just wired the switch line and N+E
i have put a link between the L sw and L and left the battery disconnected
is this right?
the lamp lit before i finished putting the cover on the bulkhead base then i turned it off and while fixing the cover i dropped the lamp and smashed it
i got another 28w but now not working
are 2D lamps ther same as PL-Q cos the original was a 2D and the one i replaced it with was a PL_Q
is this right?
