Scenario is:
160A TPN supply, needs to feed two DBs; one of which is being replaced.
The supply conductors will be 70mm (SWA/XLPE)
The board to be replaced is within 3 metres of the local isolation for the supply; the other is approx 10 metres away from the first board.
The furthest DB requires an 80A/phase supply - plan was to use 35mm SWA as a sub - but that is going to need fusing down from 160A
I don`t have the space to introduce a full panelboard - so I can`t sub it from the "new" board on an MCCB
An 80A switchfuse won`t take ONE 70mm, let alone two of `em.
So the choices are:
1. A stand-alone MCCB enclosure - lug the 70mm onto the MCCB, and take the 35mms off to the 2nd DB
2. Take the 70mm into the new DB, then run 35mm internally through to the S/F, and go from there - but where can the 35mm be connected? (Dorman smith DB)
3. Do something completely different!!!
Your thoughts would be appreciated.
KME
So the choices are:
KME
