Sorry it’s 4 chargers
4 x 32amps
So... you'll have a 3 phase supply supplying 1 phase @ 64A and 2 phases at 32A.... unless you're adding something else then do your calculations to that
4 x 32amps
it is in a duct under ground with 5 other SWA
I missed that bit, 120mm it is then...Also, don't forget to add the grouping factor for your cable, if all 6 cables are in the one duct.
