I Can't Make My Diplomat Oven Work
Status
Not open for further replies.
Debedeedotorg
Mar 14, 2015
2
Dulwich
It won't let me reset the timer. I have switched on and off. Pressing the hand does nothing. I'm hungry!!! :( (
It sounds like you have an oven that has a safety feature that won't allow the oven to operate without the timer being set.... You need to read the manual and follow the clock setting instructions.
Other than that I don't think anyone can give you any further guidance as you've posted very little information,,, not even the model number
to set the clock, you normally have to press and hold 2 of the buttons together, then use the + and - buttons to adjust the time.
In the absence of a manual, just try different ones until you find which ones work.
Only when the clock is set will the oven turn on.
Status
