Rob_the_rich
Sock Muncher
- Mar 2, 2010
- 1,343
- 27
is 10" tails enough? shouldn't you give yourself enough pipe to get you to where the manifold will be sited. else you will have joints under the floorCheers. Someone on another forum reckons to just shift the prongs to the inside and I should be good to go. Less chance of it springing off as it's PEX rather than Pert.
As I've not even got a manifold yet I was thinking on the same lines for testing i.e. lash something up. In fact for a good while it won't be even connected, manifold or not as I'm having to leave 10' tails where it comes out the door as the room it goes across isn't trenched yet to get to where the manifold's going.
