L Plate
- May 22, 2009
- 250
- 0
Hello and Evening all,
A friend of mine has a trouble with his socket in the living room , yesterday I tried to find the fault but I go back home with a smile in my face because I was not able to find the fault LOL... in my thought , that was a bit of a challenging situation, I go back again today and tried it again but still can't find the fault ...
here is the situation ... the problem on the trip on the whole circuit early last week started when he tried to fixed his shower bcoz the cable was melted , so he cut it and replace it with the same size of cable using connector block , but since then he has trouble in the whole circuit, so what he did , he took the 30A fused that supplies the ring..
the fuse board was old with rewirable fuses rated 30A, 5A, and 15A..
In the ring circuit there is 3 red cable together , 2 solid 2.5 and a 2.5 stranded wire , ( this makes me confused why there are 3 cable in the ring circuit ) so I assume that must be a spare supply,
step 1 . out of the 3 cable, I took off the one in stranded and leave the 2 solid together and it works except the 3 sockets in the living room , but if i will put back the stranded wire it tripped the whole circuit..
step 2.. I took off the stranded wire again both , red, black and earth and disconnect all those 3 outlets which is not working but still there is a sign of continuity ( using T50 tester ) :C :C :C ...
step 3 .. the same on step 2 but this time I checked the upstairs socket and there is no continuity ,,,, OMG the more i got :C :C :C LOL
I know that those stranded 2.5 cable caused the trip but i can't go further on checking it because my access is limited E.g. taking off the floor boards and see where those cable feed to.
I was challenge myself and really enjoy working on it just to find the fault. the thing is , my mates rented the house so its the landlords responsibility to send someone to fixed it .. I don't ask any from my mates though bcoz he knows that I am trying to explore my knowledge in fault findings... so again I go back home today with the same feeling of annoyed , gutted bcoz i did not able to find the fault .. BUT my personal findings is, the 2.5 stranded cable is connected to the JB and from the JB they took another feed to somewhere that caused the trip , but again maybe if i have a chance to knocked off those floor boards i would be much happy today..
anyway , this is just a small share , as you all know that I am still on my learning zone ...but can anyone think of what cause the fault is ..
cheeers and have a nice weekend to all...
