old wrinkly
- Mar 12, 2011
- 23
- 0
I recently had a new Gledhill EnviroFoam SE42X16IND Hot Water Cylinder installed. In accordance with the instructions with the tank I also had a new Euralloy 27 inch immersion heater & stat fitted, manufactured by Tesla(UK) Ltd of Birmingham.
As I am currently on Economy 7 for electric (I am reviewing this as my figures, provisionally confirmed by NPower, suggest it may not be the best option despite using 26% of my electric on night rate) I was running the immersion via a Greenbrook T!05-C 7 day digital timer with two "On" periods, one for 4 hours during night rate and the other for 3 hours during the evening (day rate) to cater for showering.
At first everything seemed OK but then after 4 days I found that the stat had tripped out so no hot water. Spoke to the retailer who told me to just press the reset and everything would be fine from then on (they seemed aware of some issues of this nature). Did as asked and started working again but then approx every 4 days the stat would trip out. Usually I would find this out in the morning.
Spoke to retailer again and they suggested taking a replacement immersion heater and stat. Replaced the stat as a first step with a new Backermatic but problem still persisted. The Backermatic is preset to 60C and has a silicon blob to prevent adjustment of the temperature.
Although I had changed the stat I contacted Tesla as I had the problem on both makes of stat and their immersion heater was still fitted and they told me the problem was easily solved. They said the stat was detecting the ambient temperature in the airing cupboard and when this reached 70 (didn't specify C or F) it would trip. This was in accordance with EN 60335-2-73.
Told me to cut a 12 inch square hole in the ceiling of the airing cupboard to vent to the loft and fit a standard grill on the bottom of the door to provide air flow. As a test before doing this they said to run the system with the airing cupboard door left slightly open.
Ran with the door open but problem still existed. Contacted Tesla again to ask if there were any other circumstances when the stat would trip out but no answer as yet.
On Sunday I removed the Greenbrook timer and fitted a straight on/off switch with neon to see if this made any difference and I left the power permanently on. Thought this might show if it was the timer at fault but also wondered if the switching rates over night might be a cause as the stat had usually failed over night.
This morning the stat had tripped out again so only ran 2 days this time.
Have looked again at the instructions with the Tesla stat and although it says the stat will trip if the water temperature exceeds 97 degrees Celcius there is nothing about the ambient temperature.
At the suggestion of a friend I have now switched the immersion power on again and placed a temperature gauge in the cupboard. The door is still partially open but within an hour the temperature recorded 81.7F(27.6C) and still seems to be rising.
My property was built approx 1960 and the airing cupboard has no venting.
Wonder if anyone has come across this and can offer any advice as I am completely baffled. Don't want to start hacking away at the ceiling or fitting the new immersion heater without some evidence this will cure the problem.
Thanks in anticipation.
