bingagemcgee
Hello All, I hope someone can help.
I have an Elson Coral E 210l hot water tank which I believe has 2 elements, 1 at the bottom heating the main bulk of the tank and 1 at the top heating the top of the tank.
I am not on economy 7 and just have a flat rate 24 hours/day.
There is no timer and no visible thermostat.
My question is first of all, what is the best way to run this type of water heater? Should it be left on 24/7 or should I turn it on before I actually need the hot water.
I live in a 2 bedroom flat and I only need enough hot water for 2 showers each morning and could do without hot water for the rest of the day.
Also, is there any danger to just having the top element on 24/7 and having the bottom switched off? We have a 3way switch that can apparently change from off to bottom to top.
Thanks in advance for your help
