Hmm, CCU = cooker connection unit apparently, which is something I generally would not abbreviate due to the fact that CCU and CU are more commonly used so no need to add confusion.
What's a cooker control unit?
I can;t recall seeing CCU being used as reference to a consumer unit as yet, although I haven;t been here long obviously, but still.Maybe you should do a search and see how often ccu has been used when it is not referring to a consumer unit. I would suspect it would be in the sub 1%. Therefore the majority of people on here understand what CCU is used for and using it for a cooker connection unit will most likely confuse things.QED
You seem to have posted in this very recent thread (note the title):I can;t recall seeing CCU being used as reference to a consumer unit as yet, although I haven;t been here long obviously, but still.
Yes, I did notice that, brain obviously tunes out at times! Edited to add soem info above.You seem to have posted in this very recent thread (note the title)
9% (14/154) of references appear to be to cooker connection unitsMaybe you should do a search and see how often ccu has been used when it is not referring to a consumer unit. I would suspect it would be in the sub 1%. Therefore the majority of people on here understand what CCU is used for and using it for a cooker connection unit will most likely confuse things.QED
Well the "big switchie thing for a cooker" I guess is officially called (by some manufactures at least) a cooker control unit and i believe the cooker connection unit is called (again by some manufacturers) a cooker cable outlet plate (or just cooker outlet plate).9% (14/154) of references appear to be to cooker connection unitsthe remainder customer consumer unit. Not one reference to cooker control unit, other than this thread
Ah - a Cooker switch
If you search cooker control unit you get a different cooker control unit.Ah - a Cooker switch If I search CCU on SF all I get is
http://www.screwfix.com/search.do;jsessionid=C1ICRQSLAKM5GCSTHZOCFFI?_dyncharset=UTF-8&fh_search=CCU&searchbutton.x=0&searchbutton.y=0&searchbutton=submit
But its a shovel.....Well, my original point still stands anyway, I call a CCU a cooker control unit, and a CU a consumer unit, and I also call a spade a spade, so therefore, I am correct. FACT
with the cooker control unit you are on your own 91% use it on here for customer consumer unit.Well, my original point still stands anyway, I call a CCU a cooker control unit, and a CU a consumer unit, and I also call a spade a spade, so therefore, I am correct. FACT
Riiiight, cleared that right up there then! I'll add that to the front of my OSG so as not to get confused later.I think that a ccu and a ccu are significantly different that it would be hard for people to mix them up when talking about them so its not really an issue.
Not really as you still think the shovel is a spade.Riiiight, cleared that right up there then! I'll add that to the front of my OSG so as not to get confused later.
I thought a spade was supposedly a shovel?Not really as you still think the shovel is a spade. :coat
