poptynewydd
- Oct 11, 2015
- 1
- 0
New Neff single oven and induction hob to be installed.
Presently have ceramic hob wired to 32 amp cooker point, shared with single built in oven.
Cable from consumer unit is 6mm on 32amp breaker, approx length 17m.
New hob is 10.5 kw, oven is 2.9kw.
Ok to wire both to the same cooker point?
Also, Neff instructions state 'Changing the intensity of the 13/16/20 amp connection current.
Before using hob, intensity of the hob connection must be tested. follow the steps to change the current of the hob.
1. Turn on hob.
2. Within 60 seconds adjust all the hotplates to the desired power level according to the requires connection current.
power level 1 20 amp
power level 2 16 amp
power level 3 13 amp
3. turn off hotplates in sequence from lower right.'
Neff have been most unhelpful in explaining this last part.
Any help much appreciated. Thanks
1. Turn on hob.
