Hi all,
I have property that needs an earth bind installed for incoming water and gas utilities (both copper pipes all through property).
Currently there is an "earth bond" connected to the GAS entry upstairs and it goes through floor board downstairs to the water stop. The issue is it is not connected to from either end to the main earth terminal block near the CU.
Now the issue is the main earth terminal block and CU are on the bottom floor while the boiler and gas pipe entry are upstairs.
The only option I can think of is to run a 10mm cable from the terminal block to the outside wall of the house and take it upstairs to the where gas pipe entry is and bond that and connect it to the existing "bond cable" going to the water pipe downstairs. (Externally run cable will be in conduit of course). Is this correct?
