Hi all can you gland armoured cable into a 400v wall socket? This is not my usual line of work and I am doing it for an NVQ assesment which requires me to install and test a 3 phase circuit using conduit and armoured cable.
I am going to run singles from the board in dado trunking, come out of the top with conduit into an isolator and drop down below the dado to a wall socket in armoured.
I had a look in the wholesalers and the socket looks like it would require a 25-32mm gland and im pretty sure 4 core 2.5 is only a 20mm gland?
Cheers Aaron
Cheers Aaron
