evenin all.
right then,when doing an insulation test on a cooker circuit that has the oven already wired in (6mm cable) is it considered ok to isolate the oven at the cooker switch and just test the circuit upto that point or should i be un wiring the cooker and testing the rest of the wire,probably about a metre max?i dont want to risk damage to the oven.or should i be connecting live and neutral together and testing them to earth?
