I'm sure it's 12, they also do a Battery only version with 10 Year Battery which can be radio linked with other wired using a radio base on at least one other. They say accepted by most LBC, so can avoid damage to decor and reduce installation time, so due to additional works on a property this would have been a perfect solution.
Contacted LBC and gave them all the details, they replied never heard of them so its wired linked only.
Called them back to say it has a 10 Year Battery which exceeds the safe working life of the device as most should be replaced after this time anyway be it Battery or Wired, and its radio linked, and most other councils accept this as a solution.
Reply - Never heard of them, it's got to be wired !!!
These units are not cheap £100 ish, and designed to overcome issues where wiring may be an issue, which in this case it is, but in typical council style, they do not want to listen or read any information on the product, hopeless.
